Dynoed a RS2 and a rare S6+ this weekend, using a MRDyno unit (more advanced form of G-Tech that corrects for air resistance, temperature, barometric pressure, etc). The test is performed on the road, so the car is in its natural environment, with plenty of cooling air.
We tested the RS2 pre and post remap.
In standard form, it put down 250whp and 250ft-lb, after the remap ("360hp" chip that peaked at 1.7bar) it put down close to 280hp and 283ft-lb to the wheels. The measurements were taken in 2nd gear. 3rd and 4th would yield better numbers due to lower losses to inertia, with torque numbers suffering the most, due to lack of spool.
The S6+ with the 4.2L engine from the S8 puts out 326hp in stock form. It was previously tuned by one of the most reputable Audi tuners in Norway (chip, open cone filter and 3" race exhaust), with a promised power output of close to 400hp.
With the open filter, it put down 250hp and 215ft-lbs to the wheels. Not being a fan of open airfilters, I suggested to reverse tune it and put in the standard airbox with stock paper filter. It now put 255hp and 225ft-lbs to the wheels, with the power and torque curve elevated at all rpms. The biggest loss with the open filter was at approx 5000rpm, where it lost approx 15whp. With quattro, 15hp at the wheels is close to 20hp at the flywheel.
Graph # 1 shows the diference in power between cone filter and standard box
Graph # 2 shows the difference in torque
Graph # 3 shows 3 consecutive runs with stock airbox. The MRDyno unit has such good repeatability that consecutive runs will produce graphs that overlay pretty much perfectly, enabling the user to spot even minute gains or losses from mods and adjustments
