That Age old problem
  • martinjs
    • 3205
    as doug said, i presumed all my clips had sealed, till i pressure tested the system just about every clip was leaking, i couldnt understand it, then john greased them and worked a treat.
    im gonna be changing every pipe on my intake system apart from the inlet pipe-throttle body one, have to think of a solution for that, dont want to keep the original.
    martin
    • audiman
      • 4827
      The original one is good!! Its only £14 if it does go pop.
      Tom C - www.rcmr.co.uk
      Audi UR Quattro
      Audi 100 C3 2.0 5 cyl 115ps
      Audi B5 RS4 645ps 911nm
      • APNess
        • 479
        Thanks for the advice guys. There's lots of steel pipe inside that rubber hose reinforcing all that stuff you can see, and I'm gonna double up on the clips, but I've made sure some movement is available along the length of that pipe.
        Ideally, I want a steel pipe in there with decent hose on either end, double clipped, cause this boost leak thing is doing ma head in :S
        'The Bacofoil Express'...
        No more.
        Leon TDI 150 run in now.
        Very slow.
        Needs a chip.
        • diesel des
          • 3896
          I had probs like this on my golf at 2 bar boost even with fancy clips like the ones in the picture. I found that silicon hoses grip better than rubber. But the best thing i found to do was to run a bead of weld round the steel pipes about 10mm from their end to give a rib for the clips to grip on. No problems since...
          • APNess
            • 479
            Arggh - further to my team bodge style fix, the wife commented on the car as it stands right now... "How is it you've spent thousands of pounds and the car is slower?"
            Yup - ANOTHER split pipe. Sheesh. Time to strip the ol red shed down again...
            Paul N - if you read this I've PM'd you a couple of days ago about possibility of posting pipes to me or Leigh. Any chance on that? I'll try the samcos and see how long they last before doing the metal pipe thing. Gonna buy a 16 ton hydraulic press pipe bender and make my own, if need be... unless someone has one just 'lying around' or something...
            Now, where's that wall to smack my head ag... ahhh, there it is
            PJ
            No more.
            Very slow.
            Needs a chip.
            • audiman
              • 4827
              Paul, i know how your feeling. Cure one leak and it springs another, tell the wife to **** off!! She wouldnt understand. LOL. I have got a small leak somewhere, but dont know where, i have to make a pressure tester this week and find it. But its not causing major running probs luckily.
              Audi UR Quattro
              • Stick Insect
                • Dec 2003
                • 2338
                I've heard that somewhere before!
                David
