Knocking noise coming from engine
  • s2_bo
    • Oct 2005
    • 6067
    Hello,
    My RS2 has been playing up a bit lately. Its slowly losing water and also the engine has started making quite a loud knocking noise.
    At first i though it was coming from the gearbox bellhousing but i think its actually coming from the rear top of the engine.
    I have taken this video you can clearly hear the knocking noise on it which increases with the reves. This has been happening for about 2 weeks but i think it might be getting louder.
    The water leak seams to be coming from the front of the engine. Maybe its the water feed for the turbo.
    Also i found a bit of milky residue on the inside of the oil cap, Is it possible for the RS2 metal head gasket to blow?
    Compression is not down as its still boosting very hard .
    Any help much appreciated.
    Cheers.
    Bo
    91 S2 coupé - RIP
    98 S8 - Luxury barge
  • s2_bo
    • Oct 2005
    • 6067
    Ohh and the oil level is pretty much spot on too so i dont think its the tappets.
    91 S2 coupé - RIP
    • Rusty
      • 18953
      Clean the cap and then re-check in a bit. Losing water and milky doesn't sound great. Just trying to get your vid the now.
      • shark_90
        • 1475
        Doesn't sound so good mate. No loss of compression though.. hmm. Can't help but water loss + oil cap points to water getting in where it shouldn't, hopefully not weeping into a cylinder.
        Hope you get it sorted.
        1994 Audi S2 Avant - in pieces
        2006 Skoda Octavia vRS 2.0TFSi - goes fast
        1985 Audi 90 quattro - is wet
        Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
        • Rusty
          • 18953
          No luck. Can you not youtube it?
          • s2_bo
            • Oct 2005
            • 6067
            Video now on youtube but its not finnished processing yet so wont be watchable till thats done.
            Thanks for your help.
            Bo
            91 S2 coupé - RIP
            • GT500
              • Jun 2006
              • 2181
              When its been left over night take the plugs out and shine a torch down to look for zee water.
              Does the noise stay the same hot or cold?
              My knocking was the oil pump:
              https://<embed width="448" height="3...22007004.flv">
              Take the belts off first. pas can make similar noise.
              HTH
              Rob..
              87 UR 20v ABY
              97 S6 Avant
              • Rusty
                • 18953
                Difficult to diagnose on the video but IMO that sounds really unhealthy mate . If it's not manifold or pump related then I think it's going to be head-off time and start wobbling some pistons, not heard a noise like that just from a weak or gone HG but that's not asying much . Surely you've got a few RS2 engines lying about, or if you haven't then Stu certainly will Just Whip the head off and have a look if there's nothing obvious... 'just'
                • Rusty
                  • 18953
                  Almost forgot, a touch of WD40 on the belts shuts them up, worked a treat diagnosing a bad noise on mine.
                  • EspenW
                    • Apr 2007
                    • 1534
                    • Country: Norway
                    My guess is rod knock, ie. a busted rod bearing.
                    It usually sounds like it comes from the head. Had the same thing on my Golf. Replaced them in an afternoon, and it has been golden ever since.
                    You can replace the rod bearings w/o pulling the engine. Remove oil pan and slide new bearings into place. Might be wise to plastigauge the mains, but they take a lot of abuse, mine were still within new spec after 240K (kms)
                    Don't drive the car as it is now, or a rod might pop out to say hi.
                    1994 80E Avant
                    1986 2L Golf 2 on Alcohol
                    • G60Rallye
                      • Dec 2006
                      • 1321
                      Deffinatly sounds engine related. Rythmical, and increases/ decreases with engine speed. Like has been said clean the cap off then take it for a drive, make sure it fully heats up and have another look at the cap. Also worth holding your hand over the oil filler hole to feel if there is much air being forced out.
                      • EspenW
                        • Apr 2007
                        • 1534
                        • Country: Norway
                        On second thought, it might not sound as harsh as rod knock. Exhaust leak in another possibility. Check manifold for cracks.
                        Also make sure nothing is rubbing on the pulleys. Almost sounds like a plastic cover touching pulley teeth.
                        1994 80E Avant
                        • Pirvu Eugen
                          • Apr 2007
                          • 1978
                          • Country: Romania
                          I dont want to scare you...but sounds like a piston or rod bearing. You can try to disconect 1 spark at the time and check iff the noise disapiers...iff yes..is a piston slap.
                          I hope i am wrong!
                          All the best!
                          Eugen
                          • mcandmar
                            • Apr 2004
                            • 5118
                            Check the spark plugs incase one has worked loose. Unfortunately it does sound like a head gasket or rod bearing
                            91CQ20v - Gone to a new home
                            93UR-S4 - The Magic Carpet
                            94S2Bus - The Emerald Express
                            • EspenW
                              • Apr 2007
                              • 1534
                              • Country: Norway
                              1994 80E Avant
