Inexpensive (and good) lambda sensor
  • EspenW
    • Apr 2007
    • 1534
    • Country: Norway
    Just installed one of these: http://cgi.ebay.com/Top-Quality-Oxyg...1%7C240%3A1318
    on a 2.0E equipped 80 Avant. At less than £20 including shipping across the North Sea, I had little to lose. It is a universal type, so i cut, soldered and heat shrinked the leads and connectors from the original lambda sensor (survived 260K on this car). The replacement works great, rapidly fluctuating between approx 0.1v and 0.8v as it should. I've previously had a bad experience with a no name sensor from Biltema (Scandinavias Halfords, sort of) that would give nuts values under slight load. The one from England works great, been checking the values with VAG-Com during driving.
    1994 80E Avant
    1986 2L Golf 2 on Alcohol
  • CoupeWannabeS2
    • 403
    So will this item fit the an S2 ?
    I have an ABY, and thinking the 13 year old lambda may need to be changed.
    • EspenW
      • Apr 2007
      • 1534
      • Country: Norway
      It sure will. Cut the harness of the original sensor, solder or crimp black to black and the two white leads on the new one to the two white leads on the harness, which one doesn't matter as thes are the leads for the heater. Make sure to use proper heat shrink (I used two layers), as you don't want these to short circuit.
      1994 80E Avant
      • CoupeWannabeS2
        • 403
        Awesome - thanks for sharing your experience.
        That is a great money saving tip, I can use the savings to top up the fuel tank.
        • europeanme
          • Oct 2005
          • 3817
          this dude is literally 5 minutes up the road!!!....
