All most ****ed myself when I found this today: radiator fan connector
  • Josh-stateside
    • 741
    I thought just the fan might be messed up.. Glad I check the connector. Seemingly some one extented the wires on the fan and did an awful job connecting the wires. I think I understand why my 7a motor dropped a vavle now.
    so:
    80 amp fuseable link is going on the ground wire
    new fan
    new resistor
    New wiring
    new connector
    steaming now..
    But I would be through the roof if I blew the aby motor.
    Josh
    P.s. not to mention bently has the 7a schematics written wrong. Something else to piss me off. I spent half the day comparing what s2central.com had to say about the 3b radiator stuff and the the 7a bently schematics.
  • Rob W
    • 353
    ooh nasty
    Rob W
    04 Audi S4 Avant
    55 Merc 220cdi c class estate Family hack.
    92 Audi S2 3b Sadly gone.
    1969 mustang fastback 302. Dry storage
    • Stick Insect
      • Dec 2003
      • 2338
      Josh, That's scary, especially in a potentially hot climate.
      Glad you found it before any more faults occur!.
      Thanks for the post, others may want to check.
      David
      • Josh-stateside
        • 741
        David
        if you want to fix it:
        Description Audi Part Number Quantity
        Fuse Box 281 937 505A (1)
        80A Fusible Link strip N 017 125 3( 1)
        Screws for mounting wiring lug to fusible link inside the fuse box, M5 x 8 mm N 014 128 11 (2)
        Lock washers for mounting fusible link N 012 005 3 (2)
        Screws for mounting the fuse box to the bracket N 013 966 26 (2)
        Lock washers for mounting screws N 011 556 2 (2)
        Bracket for mounting fuse box, secures to the cooling reservoir bracket 443 971 845 AM (1)
        read up at s2 central.com seemingly you s2 guys shouldn't have to worry about this..
        • Ski
          • 2591
          im worried about mine.. the fan kicks in when im stuck in traffic, but since i have been around this s2 (since i owned it and knew previous owner), ive never heard the fan kick in while engine is off... should i be worried?
          ABY Coupe
          • panzerwagen
            • 900
            Glad you found the problem Josh....
            Apparently it seems you have now become one of the numerous owners who have suffered the fan connector botch job. As you have stated, the previous owner was well aware of the cooling fan ground problem but did a ham fisted job fixing it, unfortunate. Well at least you now have taken care of this screw up and have one less thing to worry about.
            • Ski
              • 2591
              how do i check mine?
              ABY Coupe
                Isn't a problem on the S2 to my knowledge, but it was on earlier Coupes, 80 and other models.
                • s2avant
                  • 2426
                  It's the way Audi wire up their fans. Every VW I've owned has been able to run the rad fan after the ignition is off but Audi wire them to the ignition system. If the system is too hot though it can override and turn back on. I've only ever heard mine do it once though.
                  Ben
                  • Josh-stateside
                    • 741
                    I check my fan today. It actually works perfectly and is a three speed fan. I also check the resistor and it works fine too. It's rated at 350watts and I think I will be happy enough with this setup for now especially since I am only running stock turbo and chip. That disconnected wire basically messed up things quite a bit. It's weird thought becuase there should only be a two stage fan in my coupe but some one must of replaced it with a three stage fan. I can't complain for once I actually benifited from a **** up. I been going through the wiring and it seems I should be able to use the HI-2 speed once I source a 50 or 70 amp relay. I am still going to install a fuseable link, and possibly another relay in front of the wiring. But things are looking positive.
                    Josh.
