Hello!
I have a set off Bosch 0-280-150-803 injectors for my project but i saw that they are low impedance...
Is any way I can use them with the AAN Ecu? Resistors? How big?
Thank You!
All the best!
Eugen
Hello!
I have a set off Bosch 0-280-150-803 injectors for my project but i saw that they are low impedance...Is any way I can use them with the AAN Ecu? Resistors? How big?
Thank You! All the best! Eugen
This not going to help but I thought RS2 injectors were 944 turbo injectors. They are not. RS2 injectors are 0 280 150 984, 32.9 lb/hr 345.8 cc/min (at 3 Bar) HIGH impedance whereas 944 0 280 150 803 injectors are 37.1 lb/hr 390 cc/min (again at 3 Bar) LOW impedance. Reference:
Thanks! That is the site where i have found the data about them..
the 803 are rated for porsche 944 low impedance and 984 are simply Porsche and high impedance..
I will really whant to use the 803 ones.... but dont know what to do....
In a old post Mihnea said something about fring the power output stages for the injectors insight the ecu iff we use low impedance injectors...
I whant to be sure.
Thank You Very Much!
All the best!
Eugen
