Urgent-Turbo Oil lines
  • Billman
    • 4129
    Hi,
    a quick question, how long should approx. the oil lines be in order to fit a header on the RS2?
    thanks
    Go Holset or Go RS4
  • Billman
    • 4129
    ok, i ordered it now a bit longer, hope it doesnt matter.
    The oil feed will be approx 40-50cm long and the oil return will be approx 40cm Long. I hope it is ok. I have made them longer so in the future i can use them with a header or a bigger EM.
    Is it easy to block the water lines (turbo is only oil fed).
    Go Holset or Go RS4
