Quick & Dirty from manual in no particular order - for Graham & others...
TIMING BELT
Crankshaft harmonic damper = 450Nm or 200Nm plus 180 degrees
Do NOT use transmission to lock engine - proper tool required
Coolant pump and idle bolts = 20Nm
Camshaft sprocket bolt = 65Nm
TURBO & Exhaust Manifold
Oil return pipe bolts = 10Nm
Coolant return pipe bolt = 25Nm
Adapter for above = 30Nm
Coolant feed pipe =30Nm
Adapter for above = 35Nm
Oil feed pipe bolts = 10Nm
Turbo to downpipe = 40Nm
Wastegate to downpipe = 25Nm
Banjo bolt to WG = 25Nm
Wastegate to manifold = 25Nm
Turbo to manifold = 60Nm
Manifold to head = 25Nm
CYLINDER HEAD
Camshaft bearing cap nuts = 15Nm
After installing camshafts or hydraulic tappets you MUST wait 30 mins before starting engine. Turn crankshaft by hand thru two full rotations to ensure there is no piston contact with valves.
Inlet manifold to head = 20Nm
Camshaft cover bolts = 10Nm, tightened diagonally
Exhaust manifold to head = 25Nm
Coil pack to cam cover = 10Nm
Cam cover bolts = 10Nm
Water rail bolts = 10Nm
Cylinder head bolts MUST be of same spec (eg 10.9). Tightening sequence is a diagonal spiral sequence starting from the center of the head in three stages.
Stage 1 = 40Nm
Stage 2 = 60Nm
Stage 3 = 180 degrees
All done cold.
TIMING BELT
CYLINDER HEAD
Stage 1 = 40Nm
Stage 2 = 60Nm
All done cold.
what does your manual say the 3 M6 bolts that hold the belt tensioner onto the block? Mine says 20Nm which is wrong for M6.
