i've noticed an allen key bolt on top of my wastegate and wondered if it was some kind of adjuster. will adjusting the allen key bolt on top of my wastegate give me more boost. if it does which way does it turn, how many turns should i do it and what are the pros and cons of this.
s2 3b wastegate
Yes, there you can adjust the spring pressure in the Wastgate. More spring pressure will give you more boost in the case that the ECU does NOT control the boost: 'limp home mode' in the case of some failure, fall back to mechanical boost pressure regulation..
and a slightly faster spool-up in the normal case.
Well done should this adjustment be made according to your customized ECU mapping, as the ECU will not be able to adapt to a high level of spring 'tuning'.Last edited by Smiley; 7 December 2008, 20:06.'93 Audi S2 Avant panthero black, 412.000km
'94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
'93 Audi S4 C4 Avant, 260Tkm
'88 Audi 100 Avant turbo 44Q
'84 Audi 80 quattro tornado red
