fastech tuning chip
  • CoCaine
    • May 2008
    • 216
    • Home: Romania Current: Spain
    fastech tuning chip
    Does anyone know if the Fastech Tuning Chips are relyable?
    They say the eproms give +60 hp and +72 Nm.
    Thanks alot,
    Costan.
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    they
    worked fine on my urs4 some years ago
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
    • Smiley
      • Jun 2005
      • 329
      Not sure, maybe i use one?
      I cannot say that these are reliable, don't have checked for unusual detonation or fuel ratio..
      Never had troubles with the ECU. Once the limp home has been active somewhen last year (Inlet Temp sensor?) And oh, yes, one of the sensors at the gearbox (G4) failed and the ECU stopped the engine immediately - surprise!
      Other hassels where always related to boost leaks
      So i think everything right with the chipset.
      The mpg is slightly better. Most of the time I'm rolling off boost (traffic..). Overboost is somwhere near 1.5 (ABY here) going to 1.1 down at high revs.
      HTH
      ..trying to verify that i really use fastech, bought the chips years ago..
      '93 Audi S2 Avant panthero black, 412.000km
      '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
      '93 Audi S4 C4 Avant, 260Tkm
      '88 Audi 100 Avant turbo 44Q
      '84 Audi 80 quattro tornado red
        I'd prefer a homefry chip to be honest, cheap, reliable and dyno proven to near 300 bhp on a stock turbo with the right setup.
        • philKS2
          • Sep 2006
          • 370
          No experience of them, but I would definately second that vote for the "homefry" from paul nugent (www.s2central.net) is fantastic value for money. I haven't had my car dyno'd since ..but for £250 it certainly delivers loads of extra power and torque.
          SOLD !
          • Rusty
            • 18953
            ABY or 3B tho, profile pic is a 3B...
              1.1bar at high revs concerns me for the life expectancy of a K24... I'd like to try it in real time mode on a car fitted with a bigger intercooler and AFR gauge - its probably OK in short bursts like on trackdays but thats a lot of punishment on a hard driven daily driver. Gets me thinking again about ways to run two maps and have a 'mode' switch in the cockpit which selects your mood... Very very easy to do on the 3B, and a bit more complex for ABY/ADU but it is something I am working on - due to popular demand shall we say ;-)
              • Smiley
                • Jun 2005
                • 329
                My state of 1.1 was about revs around 5500-6500 1/min, I personally never go higher..
                "High" revs may be defined different here
                  Yeah I'm thinking 7000 when you say high revs...
                  • GazzaG60
                    • 4133
                    whats the point in taking a k24 to 7k when they drop off after 5k?
                      Peak power on stock cams is about 5800rpm from memory... with the right internals (solid lifters etc) and mapping you could run to 8000 if you wish on a bigger turbo.
