Bloomin' Hall Sensors
  • Rusty
    • 18953
    Well for the second time in 3 starts today the old girl decided to play up! Disconnect the hall sensors, wiggle the plugs a little, all good Will need to sort this as I can't afford to get stranded somewhere! I thought it was the crank sensor but I just got the car started playing with the cam sensor...
  • Knight Rider S4
    • 3541
    I would check the wiring first..(plug) before looking at the sender ..had the same on mine and the wiring was bare and broken under the connection cover
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • Rusty
      • 18953
      Yeah, the sensors are more than likely fine but the wiring has a mind of its own!
