Wastegate diaphragm test vacuum pressure
  • Andyh-R6S
    • Jan 2008
    • 157
    Hi all again,
    What would be the maximum vacuum pressure you would apply to the top section of a standard Audi S6 wastegate, to test the diaphragm?
    Should the vacuum pressure hold for a couple of minutes or until I disconnect the vacuum pump.
    Mine is graduated in “0 to 76 cm Hg & 0 to 30 in Hg”
    Regards,
    Andy H.
  • yodasfro
    • Apr 2006
    • 129
    Austin
    1992 urs4 1991 200 20v avant 1990 90q 20v
