Injector Cleaning
  • Andyh-R6S
    • Jan 2008
    • 157
    Injector Cleaning
    I am thinking of having the injectors cleaned in my S6, as it is now just clocked over ‘113800 miles’ and since the car will not be used for a few weeks again. I was wondering, apart from replacing the injector seals for when I fit them back, is there anything else worth doing too? (The last item remaining from last lot of works on the car)
    I am going to use the following company “ http://www.injectorcleaning.co.uk/index.htm “ to clean them. How much fuel will flow when I remove them? (Battery disconnected of course!)
    Regards,
    Andy H.
  • iain1067
    • 984
    Not much fuel will come out, i would de pressurise the system first, easiest place to do it would be the fuel filter (left hand inner wing) just undo one of the banjo bolts a bit and catch the excess with a rag.
    iain
    • Andyh-R6S
      • Jan 2008
      • 157
      Ta,
      Sounds good to me.
      • gavs20v
        • Sep 2004
        • 3057
        Not sure whereabouts in kent you are but theres a place just outside canterbury that clean injectors, ive used them a couple of times and they did a really good job.
        S2 Cabriolet.........
        • dubmeister
          • 522
          Regards,
          Andy H.
          The ASNU system is by far the best. Don't know where you are in Kent but these guys have the Asnu cleaner might be worth giving them a call and see if they do a while you wait service- it only takes an hour or so to clean and service the injectors.
          http://www.austec.co.uk/Rolling-Road.asp
          Would save the hassle of postage and having the car off the road.
          Worth fitting a new fuel filter before the new injectors are installed.
          • s2driveruk
            • 12696
            I had mine done last year at an asnu service centre (actually the one above) with a i think 48hr door to door - great service and nice before/after flow details.
            1992 3b S2 Coupe
            • driftin jo
              • Sep 2007
              • 2222
              just curious, how bad were your injectors before they were cleaned according to there before and after flow details ? Was the car much smoother at idle/ better generally after ?
              • pixsaudisex2
                • Sep 2004
                • 3110
                See i thought this was a thing of the past with modern fuels etc.. like saying im having my head taken off to get the valves decoked.
                So did it make much diffrence getting them done..
                • s2driveruk
                  • 12696
                  clipped from my project Can of Worms thread:
                  Also had the injectors serviced and arrived back this morning, top service and quick turnaround. All been flow tested:
                  Before
                  1 - 84cc flow
                  2 - 82cc
                  3 - 83cc
                  4 - 84cc
                  5 - 81cc
                  After:
                  All 85cc flow tested at 3bar for 30secs following a 30min ultrasonic clean.
                  New filter baskets, top and bottom seals, pintle caps were fitted to complete the service.
                  All original injectors and mileage wise about 175k prior to servicing them if that helps........?
                  David
                  1992 3b S2 Coupe
                  • dubmeister
                    • 522
                    Had an injector cleaning rig where i used to work- most injectors flowed well enough(except the odd really scrap ones) but the main difference before and after cleaning was with the spray pattern.
                    Some injectors flowed the same fuel- but the spray patterns were all over the place!
                    Like in this pic:http://www.injectorcleaning.co.uk/spray.htm
                    Most cars are smoother running and use less fuel after cleaning as the patterns are optimised and spraying into the correct areas, rather than spraying everywhere.
                    HTH
                    • Audi Parts Guru
                      • 1317
                      It is extremely rare for a set of injectors to all be flowing the exact same amount after they have been cleaned. Hence why you need several sets of injectors of the same part number in order to pick and choose enough to make up a matched set
                      S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
