I was wondering...
can someone verify if the ignition timing that can be seen on the VAGCOM log(cant remember which one it is though,but there is one),is the one that is given through the mapping?
For example if i were to copy the degrees of timing i see on the vagcom to use on an aftermarket ECU,could i do it from there?
You can log the degrees through vagcom and see the degrees throughout the rev range,so could that be used?
cheers
vasilis
cheers
vasilis
