034 gt3071r chipset
  • peter
    • Dec 2004
    • 96
    034 gt3071r chipset
    just wanted to report on this setup as hadnt seen any other posts.
    034 motorsport chipset(26 psi),green injectors,w/gate spring,4 bar pressure reg.
    having had the car running on bigger injectors/maf on pressure side/custom setup etc,the 034 setup feels much better for everyday use and fuel economy,the car idles as standard with no glitches at any range in the revs.from experience i would say approx 400bhp with 22+ mpg.wideband sensor showed very good mixture control all within spec.
    very impressed for the money
    you can request the chips to be set at 23 or 26 psi or switchable.
    i will post some rroad figures later next month if any interest.
    engine spec-
    rs2 strengthened
    tubular ex manifold
    gt3071r
    3" system
  • jade
    • Jan 2005
    • 1811
    • Home: New Zealand Current: Spain
    Well i have a 034 chip set which i have removed, as i do not see much more than 300hp with this chip set, i will be sending it back for testing as i am not happy.
    Regards
    RS 2 580HP
    • Bram
      • Aug 2006
      • 2582
      What I have seen from the 034MS GT3071R stage 1 chipset and what are my impressions; is very stable and on the safe-side tuning taking OEM internal engine parts in to account. Probably good value for money if you do not want to start a complete engine rebuild.
      For my setup (with modified engine internals) I want to take the max out of the GT3071R so thats why I went for custom GT3071R Motronic tuning giving me 368 HP at the wheels, which is more than the claimed max 350 WHP by 034MS with 7A cams. I think a custom mapping will give you more fun , earlier spool-up of the turbo, if you have the possibility to have somebody helping mapping your car.
      • peter
        • Dec 2004
        • 96
        was this 300whp or at the engine?
        the only problem i had was making sure the r201 resistor value was correct as the ecu had had other chips in it before.once this was at the specs on the website all seemed ok,i will post the rroad figures next month.
        • jade
          • Jan 2005
          • 1811
          300hp crank, car runs well but no power
          RS 2 580HP
