turbo fitment angle
  • andyg plym
    • Nov 2006
    • 4646
    turbo fitment angle
    will a turbo not operate correctly if not sat upright? my s2 was fitted wit a tubular manifold before i took it back and so when the turbo is fitted it sits 90 degrees from upright.
    just trying to suss it out as stu and bo very kindly had a look yesterday as im trying to get to the bottom of having no boost...not even 0.4 mecanical.
    perhaps oil not draining thru properly etc
  • johne
    • Apr 2007
    • 1405
    Not an expert but my understanding is that in a turbo with plain bearings the oil is expected to foam at the high RPM involved, hence the large diameter oil return pipe to the sump so the oil foam can drain effectively back to the sump to dissipate. So following that logic, the turbo housing should have the oil return outlet on the bottom.
    John
    • kwlw
      • Sep 2004
      • 1025
      • Country: Lithuania
      John
      You are right. You can put snails whatever angle you want, just retain center section pipes geometry as it it on stock manifold.
      Sau
      • Keeper of The Kitten
        • Dec 2003
        • 2317
        Interesting - are you saying the shaft is at a strange angle? I would prefer that to sit horizontally (or close to) in an application that sees regular use. If the oil is being pumped in, the return should still be getting pushed back out again, but a nice vertical exit for the oil would clearly allow gravity to aid in returning oil.
        Martin Cutting
        • andyg plym
          • Nov 2006
          • 4646
          i know you can rotate it,but was wantin to know if it would affect turbo.
          not boostin at all,usual pipes replaced etc.
            If you are not getting any boost at all then you have to stop clutching at the peripherals and look at the source i.e the turbo itself.
            Have you checked to see if the inlet shaft is spinning in the turbo and if there is any play?
            At worse the turbo could be seized or even worse the blades have broken.
            • andyg plym
              • Nov 2006
              • 4646
              jamo,3rd s2 now so done usual suspects. turbo was from my avant, works fine. Saw all blades when i rotated front housing for bottom boost hose.
              • GazzaG60
                • 4133
                jamo is right i think.
                oil goes in the top and out the bottom on the turbo
                take the air feed pipe off. take a pic of the fins. spin it with your finger too.
                check that hose for a big issue.
                next id say the wastyegate maybe if you haven't checked it. make sure it aint stuck open fully.
                • andyg plym
                  • Nov 2006
                  • 4646
                  done all mentioned,,,,,but thanks!
                  • andyg plym
                    • Nov 2006
                    • 4646
                    look at pipes at side of turbo
                    • GazzaG60
                      • 4133
                      oil feed looks to be on a bit of an angle. what this may cause is dry bearings on one side slightly. best to have a vertical feed in.
                      you should be able to clock that straight.
                      i really cannot see this being the issue though.
                      siezing it or doing the besrings in would be noticable in sound. also there may well be oil everywhere in the turbo if this was the case as the seals would have took it.
                      i can understand your frustration with this one but id be fully inspecting the wastegate, manifold and turbo if you are 100% evereything else is good
                      • Knight Rider S4
                        • 3541
                        Have you tried swapping the ECU's...?
                        93 S2 Avant Parting
                        91 URQ RR
                        02 A4 tdi Avant
                        • andyg plym
                          • Nov 2006
                          • 4646
                          yes ecu fine,its a paul N special came out of my avant and was originally from my coupe before we swapped 1st time
