Any interest in switchable chipsets ?
    #91
    Originally posted by Aurélien
    That's perfect paul .
    Just using a 3position swtich bouton ...
    16.0 AFR for economy map , at low load ...
    I cannot get 16 AFR in closed loop without external hardware that fakes the lambda signal. The ECU will always aim for 14.7 in closed loop. The valet / economy mode I am suggesting quietly disables active boost control - so it runs to mechanical boost only... About 0.4bar on the factory spring - more if its been wound down - and even more if a big fat spring is fitted. Just an idea at this stage.
    • 20Vcqdriver
      • 829
      I'm working on a 3 mode system idea - give me some time to work it thru properly. Hopefully something along the lines of
      Mode 1 = Normal or Low Boost (or Factory mode)
      Mode 2 = Sport or High Boost
      Mode 3 = Overrides either 1 or 2 into economy / valet mode
      Achieved with two external switches that link into the ECU - I found an area where I can do that cleanly.
      Should be viable OK on RR, 3B, AAN, ABY and ADU.
      Does this sound good ?
      I need a few weeks.
      Sounds perfic Paul.
      1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
      • bulldog-cox
        • Jan 2009
        • 21
        • Country: Romania
        #93
        it's a great idea!
        S6 C4 1996
        • urS6Tom
          • 773
          This is exactly what I've been looking for! Very interested to see how things pan out...
          • Zoig
            • Sep 2008
            • 555
            Paul, any news on the progress?
            • Audi-Porsche Avant RS2
              • Sep 2008
              • 1041
              • Country: Italy
              #96
              Hello, are available also for stock ADU?
              Thanks a lot!
              Bye
              Alessio
              My life and my loves
              Audi S6 C4 ABT Avant
              Audi S2 Coupe ABY
              Audi S2 Avant
              Audi Cabriolet 2.0E
              • superior
                • Jul 2008
                • 88
                any idea on the costs ?
                • mouse
                  • Apr 2008
                  • 374
                  • Country: Australia
                  #98
                  Paul, Just got a little package from you.
                  I've been thinking about what sort of switches to use and want to know what are the electrical requirements / limits for the switches (voltage, current, etc) ... Specifically can I use an LED switch such as one of the two on the links below?
                  LED: Red, 3V DC
                  Contact rating: 0.5A @ 250V AC
                  Contact resistance: <50mΩ
                  Contact rating: 500mA @ 250V AC 1A @ 24V DC
                  Insulation resistance: >100MΩ
                  LED: 12V AC/DC
                  Dialectric strength: 1000V between poles
                    #99
                    That was quick alright...
                    That switch 1064 could be used alright... select a suitable resistor between the red wire (5V) and the hot side of your LED so that when the sport is activated it can illuminate the switch. Just shout if you need help with wiring that up.
                    • mouse
                      • Apr 2008
                      • 374
                      #100
                      I think I do need some help with the wiring .. attached is what I though would work but not so sure now after speaking to someone who though that the black wires would then not get 5V... Is that right and does it matter?
                      The switch has separate connections for the switch and the led.
                      • Zoig
                        • Sep 2008
                        • 555
                        Paul, have you found a solution for AAN engined car's? I PM-d you few moons back but had no reply ever since...
                        • mouse
                          • Apr 2008
                          • 374
                          #102
                          Well I installed the new ecu last night, finished in the dark so for now my switches are two pairs of wires coming out of my centre vents...
                          The standard homefried map is brilliant as many here can attest, felt like the car had suddenly woken up,
                          The V-sream though is something else! full boost (20 - 21 psi) is almost instantly there on demand. I cant believe its the same car !!
                          Awesome work Paul
                            #103
                            Cool... U have the 1st v-stream S2 in the land down under. Enjoy it responsibly :-)
                              #104
                              Sure - multimap AAN is simple enough... Will pm you back soon.
                              • Sonic
                                • Jul 2006
                                • 5514
                                #105
                                Originally posted by mouse
                                The V-scream though is something else! full boost (20 - 21 psi) is almost instantly there on demand. I cant believe its the same car !!
                                S2Forum.com Administrator
