inlet manifold gasket
  • andyg plym
    • Nov 2006
    • 4646
    anyone ever replaced one and know best place to buy? cost?
  • s2_bo
    • Oct 2005
    • 6067
    Yeah replaced that gasket plenty of times.
    Get it from Audi, its the same part for S2/RS2 etc.
    Not to expensive but cant remember the part number.
    Might be worth renewing all the bolts and washers too with stainless steel ones , also you will need a long 6mm allen with swivel head or a long extension bar for a allen key ratchet bit.
    I think i used 45mm ss bolts on the manifolds i replaced but im not 100% sure as it was a while ago..
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • andyg plym
      • Nov 2006
      • 4646
      tryin to avoid audi after last time :mischeif:
      • Flat on my back
        • Jan 2007
        • 2449
        From Vagcat...
        034129717K, couple of £'s, quattro corner's ya best bet.
        N 90355902, bolts. Stainless will weld themselves into the alloy if not protected so be carefull.
        Carlos.
        • Flat on my back
          • Jan 2007
          • 2449
          Oh yeh...
          The washers are integral to the bolts...
          Carlos.
          • andyg plym
            • Nov 2006
            • 4646
            anybody know symptons? reckon mine is blowin (or suckin)
            • Flat on my back
              • Jan 2007
              • 2449
              Lumpy idle...?
              Plumbing shops will sell aerosols to check for gas leaks, 'smoke in a can'.
              Try this as it may show up where the leak is drawing fresh air from, or do a proper job with the boost leak tester.
              Carlos.
              • andyg plym
                • Nov 2006
                • 4646
                idle is lumpy as fek! tried and tested ISV but not it. keeps cuttin out, also refer to my posts on no boost at all (sourced a turbo to fit at weekend)
                • Flat on my back
                  • Jan 2007
                  • 2449
                  Bolt removal.
                  Buy a decent hardened long reach allen key, cut the short 'L' off it and then use a socket and wrench to remove the bolts.
                  If you 'spin' the heads on the bolts it will be a pig to remove them and you will learn to swear in 14 languages...
                  Carlos.
                  • andyg plym
                    • Nov 2006
                    • 4646
                    £7 from quattro corner.....ideal
