Should an ADU engine run at the same temperature as the 3B and ABY?
Im only seeing around 70c on the rs2 during motor way driving and up to 90 in traffic.
I have tried bleeding the system a few times by running the car hot, then waiting for it to cool down a bit, opening the bleed screw and lifting the water reservoir up a bit till water flows evenly out of the rad with out bubbles.
I then replaced the screw and lowered the reservoir back down, did the same on the heater matrix hose.
Is this a correct way to bleed the system? Or should i only do it by running the car up to temperature and waiting for the fan to kick in 3 times while topping up the water reservoir?
Finlay the thermostat is stuck open then would that course it to run cool at around 70c?
Im driving to france for a couple of weeks on tuesday so would like to get it right beforehand as not to damage anything.
Also the blowers are not blowing very hot air even when set to max temp and its very cold over there so it would make sense to get it fixed.
Is the RS2 thermostat the same as the S2 one? I havent got any way of checking atm...
Thanks.
Thanks.
