VAG code help please 533
  • s2bug
    • Nov 2007
    • 484
    Have code 00553 sorry meant 533 showing.
    Where should I be looking to correct this?
    Thanks
    S2 Avant ABY
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    that would be your Mass Air Flow.... try cleaning it or fiddle around with the connector plug.
    • s2bug
      • Nov 2007
      • 484
      dow
      meant 533 "idle air control"
      not sure where to look to sort this?
      Any ideas
      Thanks
      S2 Avant ABY
      • K Simmonds
        • Dec 2007
        • 7627
        Idle stabilisation valve?
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • s2bug
          • Nov 2007
          • 484
          Not sure what it is thats what code 0533 it says on the chart
          "idle air control regulation"
          Any ideas?
          S2 Avant ABY
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            i do believe that it still is the mass air flow.
            however if you disconnect the ISV do you get a different code?
            try disconnecting either the maf or the isv and see what comes up
            • s2bug
              • Nov 2007
              • 484
              isv?
              S2 Avant ABY
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                idle stabilization valve
                • s2bug
                  • Nov 2007
                  • 484
                  Thanks
                  Just back from the kitchen as worked it out, muppet!
                  Will check it out ...
                  There seems to be a slight flat spot from off, when running along seems fine but then when <1.5 k sems to kinda stop, basically a flat spot.
                  Not sure whether this may be as I had and MTM installed with RS2 Em on now is a std EM. wouldnt have thought it would make a difference. what do you think?
                  S2 Avant ABY
