problem!
  • timucin
    • Nov 2003
    • 869
    • Country: Turkey
    Maybachstraße 3
    Phone: +49 60 74 / 9 33 28 and 9 33 78
    D-63322 Rödermark / Ober-Roden
    Fax: +49 60 74 / 9 33 16
    Quattro
    • Audi_CQ
      • 940
      • Country: Norway
      Originally posted by timucin
      this cam is 280 degree, mechanical
      Watch out for too much overlap! Not a good thing in a turbo engine. A friend tried 284 degree cams, but had to use 7A inlet cam to make it work at lower revs.
      Roger
      • Flexx
        • May 2004
        • 248
        heads were using hydarulic before ;
        my plan was to replace cam and follwer to mechanical
        i got all the parts except gears
        do you have their phone number?
        Do not have - but u will give me, I guess...
        But normally dbilas have to send u the gears for free...they have to be included...whatever...when they don't know if a RS2 is a turbo or not...well - u think they're compotent enough for that big project ?? I would not trust them, because they r not specified on Audi 20v turbo engines !!!
        • Flexx
          • May 2004
          • 248
          Roger
          U damn right
          Same problems had a friend of mine too
          • timucin
            • Nov 2003
            • 869
            • Country: Turkey
            #20
            dbilas:
            Maybachstraße 3
            Quattro
            • timucin
              • Nov 2003
              • 869
              • Country: Turkey
              #21
              **** me!
              **** my head
              i wont be able to finish this car...
              Quattro
              • martinjs
                • 3205
                is the rest of your engine together yet timucin?
                is it in the car yet?
                • Flexx
                  • May 2004
                  • 248
                  **** me!
                  **** my head
                  Cool down man....it's not easy to make a S2 goin 500+ hp....I know how it is
                  • timucin
                    • Nov 2003
                    • 869
                    • Country: Turkey
                    #24
                    no parts no experts here, how can i cool down....
                    i want to cry man....
                    Quattro
                    • timucin
                      • Nov 2003
                      • 869
                      • Country: Turkey
                      #25
                      to receive this part from dbilas, i sent lots of mails, lots of faxes,lots of money, Mihnea spent lots of time to ship them,they even asked my first girlfirend name on customs to deliver it to me, i spent too much tips to take them and finally they do not fit
                      how would you behave?
                      Quattro
                      • timucin
                        • Nov 2003
                        • 869
                        • Country: Turkey
                        #26
                        now i am going to my office i will bring the paper , conversations between me and dbilas and you will understand what i mean
                        Quattro
                        • Flexx
                          • May 2004
                          • 248
                          Timucin...
                          I understand...I will call them on Monday !!
                          The problem is & would be, that ONLY dbilas' gears can fit on the camshafts, because of the steeringtimes (I hope it called like this)...the other problems would be...that when u have the gears, u have to find the EXACT position on the camshafts !!!
                          Can I ask u how much u pay for the camshafts ? Both !
                          • Josh-stateside
                            • 741
                            "Hi
                            kent cam gears make internal adjustable cam gears for the 16v 4 cylinder motor. They should work with those cam shafts.
                            Figured I let you know.
                            If there was a problem, Yo, I'll solve it
                            Check out the hook while my DJ revolves it
                            Josh"
                            Forget that... I just read the last post.
                            I tried.
                            • spink
                              • 4382
                              quote 'If there was a problem, Yo, I'll solve it
                              Check out the hook while my DJ revolves it'
                              nearly choked on my beer reading that
                              • timucin
                                • Nov 2003
                                • 869
                                • Country: Turkey
                                #30
                                Quattro
