Oil to water coolers
  • jade
    • Jan 2005
    • 1811
    • Home: New Zealand Current: Spain
    Hi could anyone please advise on the best location to plum a oil to water cooler in i was thinking of using my aux rad take offs any thoughts
    Regards
    RS 2 580HP
    You can't use your aux rad top point as the aux rad takes hot coolant from the top of rad.
    You need to take cooler coolant from the bottom of the rad i.e the bottom hose, but then this is a tee and after speaking to Mocal about these you need to flow ideal all coolant throw the oil to water cooler.
    • Keeper of The Kitten
      • Dec 2003
      • 2317
      Bear in mind that any oil to water heat exchanger will increase the water temperature, ideally oil to air cooling would be a better solution if water cooling is marginal - which it might be at the hottest times in Spain.
      Martin Cutting
        • Dec 2003
        • 2317
        (I see you're already using a large oil cooler!)
        Martin Cutting
          Yes but not as much as you think
          I'm doing this, Terrybullwon was with me i've done all the research and it's better than air to oil
          Especially heating the oil to operating temp quicker is a big benefit.
            • Dec 2003
            • 2317
            In that case - go ahead!
            Martin Cutting
            • johne
              • Apr 2007
              • 1405
              You need to put it in the heater circuit. That way you get the benefit of flow all the time including in the warm up phase to help speed the oil warm up.
              In their time, Golfs and Metros were fitted with oil/water coolers that fitted between the oil filter and the oil filter housing and would end up extending the oil filter downwards by approx 100mm.
              I have one on my mini, great item.
              John
              • jade
                • Jan 2005
                • 1811
                John
                Plumbing it between the small metal pipe that comes of the thermostat to the rubber heater hose with bleed screw in is that what you are recommending
                RS 2 580HP
                  I never thought of there, genius
                  • jade
                    • Jan 2005
                    • 1811
                    i WILL LOOK INTO IT A LITTLE MORE, BUT THAT LOOKS LIKE THE PLACE IT,S GOING THEN
                    RS 2 580HP
                    • dimo61
                      • Feb 2007
                      • 11
                      • Country: Russian Federation
                      on AAN .......
                      • johne
                        • Apr 2007
                        • 1405
                        Yep, exactly there
                        John
                        • jade
                          • Jan 2005
                          • 1811
                          Thinking about the installation of the oil cooler & the way it will work
                          That is at start up it will help to warm oil to operating temperature.
                          I would think to take advantage of this it will be necessary to remove the oil thermostat control from the oil filter housing so this is not restricting oil flow when the engine is cold.
                          RS 2 580HP
                            Yep, that's what Mocal said
                            • jade
                              • Jan 2005
                              • 1811
                              Well looks like i,m on the right track then
                              RS 2 580HP
