Factory alarm - How do you disable?
  • RAOUL
    • Sep 2003
    • 260
    Hello gents, recently got myself a "Homefry". Car has had a mad fit, basically when we connected the battery it immediately started to lock/unlock itself repeatedly and the foglight switch now flashes red. It has never done this before! After removing fuse 19 from the main fusebox this allows the car to run and "knocks out" the central locking fault. From what i can gather the central locking pump is part of this factory burden sorry alarm! Please help, 3 months without "her" & i'm climbing the walls!!!!!!!!!!!!!!!!
    ATB
    RAOUL
  • Matt_D
    • Dec 2004
    • 515
    I had mine disabled by an alarm specialist, is there someone local you could take it too and get it disabled ?
    '95 ABY Avant - Sold
    '98 B5 S4 -MRC400+ = 464ps 741nm
    • RAOUL
      • Sep 2003
      • 260
      Not sure to be honest. I called in at my mates Autograph Cars who fitted the Clifford 10 years ago and told him about the factory alarm (not dealer fit) and he said he had never heard of it.
      ATB
      RAOUL
        Your ECU is NON-immo type Raoul... And the ECU was tested AOK on mine before I sent it back. You must have some badness going on with other wiring... Could you have disturbed some cabling when removing / refitting the ECU.
        On a Coupe of your vintage, the central locking pump controller and alarm unit are the same thing. Check out the wiring on http://S2central.net/S2_Schematics
        The offending controller unit is behind the trim in the rear seat behind RHD drivers seat - bit of a batch to get to but not too bad - some partial disassembly of rear seat.
        • ericd
          • Nov 2003
          • 1240
          you could try this
          disconnect the battery for about 2mins and just reconnect and see if it's back to "normal", usually after battery connection the hazards should flash , push the button on remote and hazards should cancel.
          or from the booklet, disconnect battery, turn ignition "on", reconnect battery, turn ignition "off", press remote button for 10 seconds.
          just remember and stick the fuse back in before doing any of the above ...
          • RAOUL
            • Sep 2003
            • 260
            Cheers Eric, i'll try that. Are you referring to the Clifford remote? I have a sneaky feeling as Paul mentioned i will have disturbed something under the dash!
            ATB
            RAOUL
            • ericd
              • Nov 2003
              • 1240
              sorry, I thought you had the factory standard keyfob, one button for arming/disarming, the other button was a panic button, I think a scorpion variant was the factory/dealer fitted alarm
