anyone identify this turbo?
  • bernsaudi
    • Feb 2007
    • 592
    hello, got a turbo i want to identify....
    customer no k26 vt 1096
    part 03 429 0002
    it is on an s2 currently
    any ideas
  • Audi Parts Guru
    • 1317
    part 03 429 0002
    any ideas
    Need some more numbers from the blue ID plate on the comp housing
    • bernsaudi
      • Feb 2007
      • 592
      those numbers were indeed off the tab on the oldside, but this is All the numbers i can find.......
      vt 109-6
      03.429.0002
      5326-101-5160
      there are some numbers on the on the bearing housing in the middle...
      r03 5886b
      cheers
      • bernsaudi
        • Feb 2007
        • 592
        I think ive found it....
        rs2 stage 1 380hp k26 turbo.....spreadsheet here...
        anyone know any details on this turbo?
        cheers
        • kwlw
          • Sep 2004
          • 1025
          • Country: Lithuania
          cheers
          At least it has RS2 cold side housing... So I can bet it's somewhat with hot side from conventional audi K26 (probably #8 housing), somewhat larger compressor wheel and RS2 cold side housing. So in general it should be very close to the RS2 turbo map.
          Sau
          • bernsaudi
            • Feb 2007
            • 592
            ello, how do you work out the housing numbers?
            • kwlw
              • Sep 2004
              • 1025
              ? What do you mean work out? 5326-101-5160 is RS2 turbo cold side casting number. This has certain physical dimensions, and for given BHP it is sane (and economically reasonable) to match it with compressor and turbine I have mentioned.
              So usually companies do it. Sometimes they don't (motorsport stuff, crazy ideas, etc.). That's why I'm guessing.
              Sau
