No Oil pressure....help!
  • 20Vcqdriver
    • 829
    My engine has been stood for 3 months while I did a few maintenance jobs including having the turbo overhauled and work on the water manifold on my 20Vt. With everything back on I decided it best to remove plugs and crank over without pressure on the components until the oil got round. Did this last year, after the install of this engine and expected to see the oil pressure light go out after 15 seconds as last time but this time nothing, did a full 30 seconds and checked for oil in the cylinder head and other than remnants from the last time it was run, Nothing! Checked oil level and all connections. Tried again and still nothing. Never had this before. Could an oil pump fail just like that after not being used?! Or is it just a vapour lock, Anyone had this and if so any ideas please, could do without any expense at the moment, so a cheap fix much appreciated...::dontknow::
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
    2004 A4 2.5TDi convertible, re-mapped to 180bhp
    2011 A5 sportback 3TDi-Backbox delete, remap
  • rash
    • Oct 2007
    • 68
    ...try the starter 30 sec.
    then 10 sec delay
    ...then again 30 sec.
    ...should work
    • AUDIS2avant
      • Jan 2009
      • 670
      • Country: Denmark
      As rash says, normally after a long time the pump can loose it´s vacum, so just keep trying, but not to loong as the bearings get´s to warm and my fry them self
      • Flat on my back
        • Jan 2007
        • 2449
        I thought there was a 'check valve' in the oil path to the head to stop oil falling back to the sump...under one of the oil pressure sensors.
        Stuck maybe...need to get home a get a piccy of it...
        Carlos.
