blinking warning light
  • kaaperdaja
    • Sep 2003
    • 143
    On the computer sometimes red warning light is blinking and just doesn't stop. I think it is the cooling water sign and it should remind me that there is not enough water but it's not the case. Could it be somekind of sensor?
    Reimo
  • pjeast73
    • 144
    It's not the brake fluid warning is it?
    • kaaperdaja
      • Sep 2003
      • 143
      No. On the bottom there are like 2 waves and in the middle is standing a tempereture symbol.
      • Floppy
        • 126
        Had this problem too.
        Check your cooling water reservoir again and if it's ok, then you have a broken sensor.
        Good luck!
        ps: fill it until you see the lower surface getting blue of the fluid, this is the max.)
