holey pipes?
  • dan_b
    • Sep 2003
    • 3670
    holey pipes?
    What's this? Is it important?
    I noticed this split in this hose on Friday at the track day when, after returning from a rather spirited run, I stopped the car, opened the bonnet and was greeted by the lovely sight (and smell) of burning oil coming from somewhere near the turbo... Anyway, the only thing that was obviously wrong was this:
    Neither Lee or I could see any sign of obvious leakage from the turbo.
  • spink
    • 4382
    Its the pipe that goes from the IM to the dump valve(on mine it is).I would say you will be sucking plenty of unmetered air into the engine, but cant see that it would be causing oil to get onto the turbo.
    • urq20v
      • Sep 2003
      • 218
      The same pipe split on my 20v Urq.I was very dissapointed with the performance of the car when I first bought bought it,until that is,I replaced the split DV vacuum/boost line.Since there is always some oil in the inlet tract,perhaps some was blown thru the split pipe and dribbled onto something hot?I re-ran the DV line on the inlet side of the motor,over the top of the injectors,less heat,less likely to split again.This is a commom failure.
      • dan_b
        • Sep 2003
        • 3670
        what's the part called exactly- I'll order a replacement tomorrow, is it ok to re-fit ?
        • Lee
          • 1512
          Buy some silicone tubing. Much better and not at all expensive. Worth changing all of the small bore hoses while you are there. Some of the ones around the throttle body are a PITA. ChrisM changed all of his recently and I recall he had a few awkeward ones which took some time.
          I need to buy some of this tubing in black for myself.
          Designun Limited....
            Totally agree with Lee on this and the hose description posted by someone else. Get yourslef a 3metre roll of 4mm ID silicone hose in your favourite colour. Its amazing how many little leaks on the old braided stuff build up over time.
            Paul
            • dan_b
              • Sep 2003
              • 3670
              Ok, sounds like a plan. Any recommended retailers?
              What other PITA small bore hoses are there?!
              Incidentally, would I be losing performance though that holey pipe?
              • Dr H
                • 1175
                Just bought 3m of black from SFS - 9.99 + VAT plus a couple of quid postage.
                SFS Performance manufactures and distributes the world's finest high performance silicone hoses. Whether you're running a race team or want to get the best performance from your road car, SFS Performance can provide the hose you need, when you need it.
                • dan_b
                  • Sep 2003
                  • 3670
                  How quickly did they supply?
                  is this stuff easy to put in place of the old hoses?
                  • spink
                    • 4382
                    I think this pipe was left unconnected after a large stripdown last year, seem to remember it only giving 0.8-1.0 bar instead of 1.4.Some of them around the bulkhead will be a bit awkward to fit.I cant be 100% but i think there is one that goes from the back of the IM to a diff lock, or maybe i am talking turd?
                    • dan_b
                      • Sep 2003
                      • 3670
                      yikes, that's a lot of lost boost. Better do this then!
                      • Stick Insect
                        • Dec 2003
                        • 2338
                        • audiman
                          • 4827
                          The oil burn bit, could be down to excessive breather fumes being dblown out the split onto the warm turbo? Just an idea, but any slight leak can cause many problems.
                          Tom C - www.rcmr.co.uk
                          Audi UR Quattro
                          Audi 100 C3 2.0 5 cyl 115ps
                          Audi B5 RS4 645ps 911nm
                          • dan_b
                            • Sep 2003
                            • 3670
                            That's what I am hoping... Looks like a PITA to find the bottom end of this pipe though Me and my car are not having a happy relationship at the moment
                            • audiman
                              • 4827
                              It just goes down to the DV. Dead easy to find, just pull out the o/s bumper insert and you should be able to see it.
                              Audi UR Quattro
