My ABY coupe has been playing up more or less since i bought it 6 or 7 months ago. It has no mods.
I can only achieve max boost pressure and overboost when the engine is cold. As soon as the engine reaches operating temperature, it cuts down to 0.4 bar mechanical boost. Sometimes when i hit WOT (at running temp) it will start to boost, then it dumps, then it boosts and dumps. Almost like switching a switch on and off!
I have disconnected the MFTS as it packed up and i thought i had found my problem - it wasnt.
I have a cone filter fitted and thought that maybe she was sucking hot air, so i made and fitted a stainless steel heat sheild. still the same.
I can drive less than a mile down the road to tesco, pop in to fetch a pint of milk, and by the time i jump back in the car, i've lost boost.
If i continue to drive, then boost lasts a bit longer.
I hope this sounds familiar to someone and maybe there are some suggestions out there?
Dan.
Dan.
