Oil Change - Sump Plug
  • MikeLarwood
    • Aug 2008
    • 278
    Does the sump plug have a copper crush washer on the S2?
  • MikeLarwood
    • Aug 2008
    • 278
    Part numbers if possible please
    • terrybullwon
      • Mar 2006
      • 8782
      Yes it does, buy both the washer and a new plug.
      Chef
      • MikeLarwood
        • Aug 2008
        • 278
        Got a new plug for christmas, but no new crush washer
          Mike, I'll see if I can find the washers I have because still in pack with number
          • terrybullwon
            • Mar 2006
            • 8782
            Try using Vatcat.com
            Chef
              About 50p from GSF
              • Flat on my back
                • Jan 2007
                • 2449
                GSP...
                Just turn it over and crush the other side...
                Carlos.
                  Ah no - he'll fail the modified concours class if he does that... LOL
                  • Jas11n
                    • 5067
                    Washer = N 0438541 (size A26x31)
                    Sump plug = 059 103 193 (M26x1.5)
                    Consider a Fumoto drain valve. No more hanging off a 6' extension bar trying to get the stupidly tight welded on plug off, before rounding it off.
                    2001 Avus Silver B5 RS4.
                    1995 S2 Coupe - sold (sniff)
                    • anton
                      • Jan 2005
                      • 802
                      i have one of these, going to be using it for the first time in a couple of weeks.........
                      is i wrong that i am actually excited about my oil change.......i think i have problems......
                      Ant
                      91' Coupe quattro 20v - project
                      KW V2s and other goodies
                      now gone
                      03' BMW 330CI - Sold
                      08' A5 Coupe 3.0l tdi quattro - Sold
                      57' BMW 525d M Sport Touring
                      • iain1067
                        • 984
                        I rarely change the sump plug on both the car and bike, never been a problem, i know you should though
                        Iain
                          Ian - you must have the only S2 that doesn't have a sump plug that welds itself to the sump then... COnsider yerself lucky.
                          • PeteRR
                            • 1326
                            I always apply a small amount of Copper grease to the threads when replacing the sump plug. Seems to work as I never have a problem undoing the plug thereafter.
                            (Though I have indeed needed the breaker bar on occasion when doing the first oil change after buying a car!)
                            • Pete Reeve
                              • May 2007
                              • 584
                              Both in stock quattro corner
                              Quattro Corner Audi OEM Parts
