evening all i wonder if you can throw some ideas my way as to what is going on .
i have notice for the last couple of months now i am down a good 50 miles on a tank of fuel. i do most of my driving doing 80mph down the motorway and latelly in the cold weather the coolant temp has been dropping down from the normal 90 to half way between the 90 and 50 now my first thoughts were the thermostat was on the way out and the high fuel usage was down to the engine not getting warm properly . so over the week end i put a new thermostat in along with fresh coolant. wilst i was in the area i checked the static timing. flywheel marks, cam timing marks, and the lines in the dizzy (3b by the way) are all perfect. now went out yesterday it now takes miles longer to warm up but doesn't really warm up at all. great i thought i knew i shouldn't of got a thermostat from gsf any way tonight i tested my old thermostat and the spair new one i bought. the new one is opening as it should and the old one is opening later than it should and not as open as the new one. so as far as i can see the one in me engine should be working correct. now this has thrown me totally have i got a fueling problem that is not warming up the engine or is it a cooling problem ?
if the engine is being over fueled will the engine run hotter than normal or colder
oh ya no fault codes stored in the ecu the olny blink code is 4444 which if i remember right is no faults pressent
any ideas welcome thanks in advance
dennis
dennis
