ecu testing aby
  • pearlwhiteS2
    • Jan 2009
    • 8
    ecu testing aby
    still having problems getting this s2 started...
    the fuse still blowing for the coils/ecu???
    checked for possible shorts etc etc ...
    putting a power probe 12v through every pin on the ecu plug and fuse ok.... connect ecu and pop the fuse...
    would it be worth having this chipped ecu checked and if so who...im in the north wales area not far from chester....
    cheers
    Very much doubt a faulty ECU is causing this, but its possible... Post up some more info and I'll see if I can guide you thru the schematic on the current path for the affected fuse...
