mfts symptoms?
  • andyg plym
    • Nov 2006
    • 4646
    mfts symptoms?
    as you all know my car is bein a proper pain at the moment. Today i finised work and drove home, all of a sudden i had BOOST!!!
    Still stuttering but at least trying. Ive noticed temp display is starting to be intermitant and wonder if mfts needs replacing?
    Ive replaced these before but never had NO boost.
    im still plannin to return the car back to stock manifold setup as the tubular doesnt seem to work on a stock k24
    i wonder if a worn out mfts will cut all boost completely? not just a bit, but all of it.
  • FITZY
    • Sep 2004
    • 194
    Mine failed back end of last year, thought my WGFV had failed as went back to mechanical boost only, replaced WGFV - still the same so dis-connected MFTS and instantly regained boost but obviously lost temp gauge op.
    If you're in any doubt just dis-connect it and see what happens, should rule it out for you one way or another
    94 S2 Avant, Crystal Silver, slightly modded
    89 Vw Golf mk2
    12 Mercedes e250cdi, silver, daily commuter
    • andyg plym
      • Nov 2006
      • 4646
      did you ave any boost at all?
      • FITZY
        • Sep 2004
        • 194
        Yes, I did (but only just) If you have your car running and give the throttle a quick 'blip' by the cable whilst under the bonnet, do you hear your WGFV clicking?
        89 Vw Golf mk2
        • andyg plym
          • Nov 2006
          • 4646
          yes clicks like its avin a fit
          • FITZY
            • Sep 2004
            • 194
            Wouldn't have thought it was a faulty MFTS then, although like I found on mine, disconnecting it proved the point. Probably a silly question, but are all the hoses in the correct orientation on the WGFV itself?
            89 Vw Golf mk2
              Andy: If your car is a 3B, the MFTS is connected to the ECU, if it is a ABY it is not, as noted here:
              http://forums.audiworld.com/s4s6/msgs/148742.phtml
              If you have the automatic climate control, it is possible to check the MFTS output to the coolant temp gauge against the coolant temp going to the heater by using Channel 51 of the climate control as described here:
              http://forums.audiworld.com/s4s6/msgs/163785.phtml
              Good luck.
              • andyg plym
                • Nov 2006
                • 4646
                yes are all fine, can a faulty mfts be knackered but still work temp display?
                • andyg plym
                  • Nov 2006
                  • 4646
                  Good luck.
                  yes its aby but maybe coincidense wiv boost issues and display intermitant
                  • FITZY
                    • Sep 2004
                    • 194
                    My temp gauge was still working fine Thats why I replaced my WGFV first because I presumed the MFTS was ok.
                    89 Vw Golf mk2
                    • Paulgo
                      • Jan 2005
                      • 498
                      When my MTFS was faulty it was retarding boost - but only by about 3-4 psi. It took me ages to identify the MTFS as the cuplrit. In the end I only realised because the temp warning light came on and stayed on (even tho the temp gauge was reading as normal) indicating the MFTS was borked, even though it must have been on its way out for months. They must be able to have an effect on boost even when they havnt failed competely and as a result thats hard to spot.
                      Try the good old tap trick which worked for me - give the MTFS a few light taps and see if it makes a difference. It did for me, albeit very temporarily when boost went fleetingly back to normal, but at least I finally knew what was keeping my boost levels down!
                      Paul
                      • AUDIS2avant
                        • Jan 2009
                        • 670
                        • Country: Denmark
                        again MFTS??? blue 4 pin sensor or?
                        • AUDIS2avant
                          • Jan 2009
                          • 670
                          • Country: Denmark
                          I cant erase the above post so here i will ask again, mine is an aby and is down a little on boost and mpg so if its not the mfts sensor that controls this is it the 2pin on the back of head then?
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            can MFTS cause a boost drop linearly at about 0.3bar on all rev range without any signs of problems when driving etc?
                            • driftin jo
                              • Sep 2007
                              • 2222
                              Good luck.
                              This link says nothing about the ABY just about the AAN ! As it happens this is one of the only things the the ABY/AAN differs on on ecu pinout.
                              The aby ECU is connected to the MFTS so it is possable that it could affect boost.
                              ref. http://s2central.net/motronic_pinout_ABY.html
