My wastegate spring is being wound down(not all the way) but enough to make the boost climb to 1.5bar towards the end of the rev range with the WGFV unhooked.
I was wondering... can that fact induce more surging when going WOT or is that irrelevant?
My map was done with the spring on the original position,however it always seemed to me that boost pressures were never met,so that is how i started tampering with it.Now EGTs and boost pressures are met,but on 5th and 6th gear WOT from 3000rpm,it tends to show some surging here and there,before the boost settles at 1.9bar.
i was wondering if the wastegate spring has anything to do with it.
cheers
vasilis
cheers
vasilis
