problems AGAIN ****!!
  • AUDIS2avant
    • Jan 2009
    • 670
    • Country: Denmark
    Getting tired now, car wont start before 3. time now from cold, mpg is off boost is falling down, almost no overboost now just a short peak.
    Dont want to change ewerything between the numberplats now, so any help would be nice?
    Have changed lambda and n75 valve for now, nothing helped
    vag-com the car, if it's aby could be hall sensor
    • AUDIS2avant
      • Jan 2009
      • 670
      • Country: Denmark
      Sure?
      Cause it´s got NO misfires engine runs perfect besides the above
      • Knight Rider S4
        • 3541
        LOL...sure!....Do a output test using vag.com and scan for codes
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
          search and you'll see.........
          • AUDIS2avant
            • Jan 2009
            • 670
            • Country: Denmark
            ok, will try, thanx
              Hall sensor if failing doesn't show up on vag-com btw btdt, but you may have other codes.
              • AUDIS2avant
                • Jan 2009
                • 670
                • Country: Denmark
                Ok, but does the hall sensor really make the car go down on boost and mpg if it´s bad?
                  Hall sensor is for non starting
                  • Knight Rider S4
                    • 3541
                    MAF is the first thing i would look at
                    93 S2 Avant Parting
                    91 URQ RR
                    02 A4 tdi Avant
                    • AUDIS2avant
                      • Jan 2009
                      • 670
                      • Country: Denmark
                      ok, hall sensor is the cam sensor?
                      Yes am planing to change maf and either 4pin or 2 pin coolant sensor, which one that controls the coldstart
                      • AUDIS2avant
                        • Jan 2009
                        • 670
                        • Country: Denmark
                        Have tried today cleaning all sensors, and all looks ok, only having start problems when engine is cold tho, not when hot.
                        Have tried the "watertrick" without luck also.
                        Am trying to sort out a vag-com session maybe tomoz
