part number req please
  • vonbeck
    • 2455
    im after the part number for the inlet temp sender?
    and is this the correct number for the coolant temp senser 035-919369m
    cheers me dears
  • k.alle
    • Feb 2008
    • 801
    035 919 369M is indeed the white sender on the cyl. head.
    034 905 379B - inlet temp sender.
    Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
    http://www.garaget.org/?car=52877
    • vonbeck
      • 2455
      cheers will piock up tomorrow
        WOrd of warning - don't just buy these for fun... Audi doesn't let you return any electrical parts - unless they delivered the wrong part.
        http://S2central.net has the info you need to quickly test an existing IAT is in spec... As long as you can use a multimeter.
        • vonbeck
          • 2455
          cheers paul these have never been changed so i suppose it wont do any harm will have a spare if no different but i think i will have to get a new maf as well though is that a main stealer part only do you know?
          • vonbeck
            • 2455
            went for these today, got the coolant senser ok from gsf went to main stealers for the inlet temp senser and was told its obsolete is this the case or does anybody know where i can get one from, also would it be beneficial to replace my maf with an rs2 one? or not cheers
