ABY Crank nose spacer
  • terrybullwon
    • Mar 2006
    • 8782
    Guys has any one got one of these to hand?
    I need to confirm the size.
    Cheers James
    Chef
  • terrybullwon
    • Mar 2006
    • 8782
    Part number is i think 034105193
    Chef
    • Flat on my back
      • Jan 2007
      • 2449
      Aelred made me a spacer up to go with my 25mm bottom sprocket...think it was cos of the 3b/aby pulley differences.
      Can measure it tonite...ID, OD and tickness ok?
      Carlos.
      • GazzaG60
        • 4133
        not got one to hand james but i have fond memories of building the engine and the belt running into the casing.
        its around the 3mm think area bout 30mm diameter
        • terrybullwon
          • Mar 2006
          • 8782
          Ok problem solved, the spacer i am using is 8mm. Carl you will have the same as me. I had to make a key way in my spacer.
          Chef
