Ecu Aby/aan
  • wastegates
    • Dec 2004
    • 351
    • Country: Spain
    Ecu Aby/aan
    I am proving an ECU S4 AAN MTM.
    Exists some problem to work in ABY?
    After many problems of operation, I have disassembled ECU of ABY and AAN, and have changed the Chips of Paul I have put and them in the ECU of the AAN and now I am trying.
    There is some problem?
    Thanks
    Charles
    Audi S2 Coupe ABY 1994
    Barcelona
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    good luck with the ECU gurus
    i am sorry because i can´t help you with nothing in ECU parameters..
    • wastegates
      • Dec 2004
      • 351
      • Country: Spain
      Pajaroooooooo, donde te metes, se te ve poquilo el pelo aunque andes camuflao jajajjajajja, bájate el video de la quedada de Arbucies, te envio el link por privado.
      To see if some Guru solves the doubt to me.
      Charles
      Barcelona
      • Knight Rider S4
        • 3541
        Immobiliser problem i suspect
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
          Putting ABY chips into AAN ECU is OK... Did you fit them right way round ?
          • wastegates
            • Dec 2004
            • 351
            • Country: Spain
            The car this working 2 weeks with ECU of AAN + Chips of Paul.
            It does not enter Limp Mode like before. desperate I changing many components by errors. Maf, lambda, fpr, spark Plugs, N80, silicone hoses, to potienciometer trhotle, and but things that now nonmemory.
            Now it leaves the error Lamba sometimes, I am going to change the gasoline pump to see if he is that.
            A greeting
            Charles
            Barcelona
