Check your plastic water connections!
  • GT500
    • Jun 2006
    • 2181
    Age related failure:
    Had my car running on sunday, after ten minutes went to see if it was all ok. It wasn't!
    Temp was 125 and low coolant warning fashing. Switching it off and opened the bonnet to find the water connection to the heater with the temp sensor in had fallen apart!
    Plastic rubbish! they are on back order and I don't want another anyway!
    Aluminium one in fabrication.
    I then removed the connection to the block, just under the rear of the head.
    Guess what, big fat crack in it!
    Next part to fab! I know URs have steel ones but they are also on back order and are £28.
    I will take some pics of the new Ali ones once I've finished them.
    Just a heads up!
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    I scaulded my face quite badly last year when the same thing happened to my after run pump. Be careful kids.
      I only paid about £10 for a new plastic on too the block about 3 months ago, err £28???? it was from Vagparts though
      • GT500
        • Jun 2006
        • 2181
        Err rear above!
        £28 for a steel one.....
        Rob..
        87 UR 20v ABY
        97 S6 Avant
          Christ that's a hike for a steel one! does it fit?
          • A80Avant
            • 10873
            • Country: Greece
            ROb,
            fabricate more! i would like those 2 myself.They are new now,but i wouldnt mind having them in aluminium!
            • AndyP
              • 6049
              Originally posted by GT500
              Err rear above!
              I got a steel one off Pete Reeve, about £21 I think.
              • Acidburn
                • 13459
                Glad no damage was done to the car, good job you went out to it in time.
                Would be interested if more of these can be made rob
                • lind4hl
                  • Jul 2008
                  • 2465
                  i would also be intrested in one of these
                  • GT500
                    • Jun 2006
                    • 2181
                    Ok, I'll suss out how long it takes to fab, I am waiting for the Ali bar arriving... once its here i'll on with it!
                    Rob..
                    87 UR 20v ABY
                    97 S6 Avant
                    • j dog
                      • Nov 2007
                      • 52
                      your coil
                      rob, pm me an address and i'll send your coil to you!
                      • mcandmar
                        • Apr 2004
                        • 5118
                        7A's also use the metal version, BUT they do suffer from corrosion. I would stick with the plastic IMO.
                        91CQ20v - Gone to a new home
                        93UR-S4 - The Magic Carpet
                        94S2Bus - The Emerald Express
                          Where are these plastic bits located? I think I might check mine after the after run pump melt down!!! Better safe than sorry Any pics would be good otherwise I'll go and have a route around, I think I know where the bits are from the description above...
                          • urquattro-island
                            • Mar 2006
                            • 1915
                            • Home: Norway Current: Iceland
                            at
                            rear of head down by the steering rack. mine blew to pieces here the other day, wooooshhhhhh
                            japanischer industriabfall nein danke!!
                            www.rackeltrim.se Icelandic Division
                              Will have a look at that then... can't be easy to get to either
