Check your plastic water connections!
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    its
    probebly more tight on the s2 then on my s6, the new runnaround, ooh reminds me have to post some pics of her..
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
      It's quite easy to see but not so much to get to. Famous last words but it's not leaking...
      • NickVyse
        • 49
        Mine came apart on a hot French autoroute last year, about 700kms from home. Had to bypass the whole heater circuit, but it got me home OK.
        I think the key is not to over tighten the clips. Bloody plastic. On the up side the French dealer had them in stock and it was less than 4 euros.
        • pixsaudisex2
          • Sep 2004
          • 3110
          I had a little leak here also ordered a new one, put my hand down the back of the engine to change it and it broke of in my hand.... what i call timming.. which reminds me i must check my spark plug tightness again soon....
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            #20
            You can still get the metal one? And there's me trying to trying to restore and preserve my original 3B one. I chucked the ABY plastic crap in the bin.
            What's this about an ali one?
            SS
            • GT500
              • Jun 2006
              • 2181
              Coming soon!
              I put one on order but its on back order... usual!
              Andy, the other one goes in the heater pipe, the one from the water rail.
              Rob..
              87 UR 20v ABY
              97 S6 Avant
              • RAOUL
                • Sep 2003
                • 260
                Hiya Rob, if you do make a batch put me down for 1 of each. I think with 220,000miles mine will be a candidate for failing when you least need it of course!
                ATB
                RAOUL
                • quattrostyle
                  • Oct 2006
                  • 6229
                  you're right, that's the main reason for failures, BTDT 3 days after tightening the clip the plastic connection blew into pieces.
                  • BrianSmith_S2
                    • Jun 2005
                    • 1342
                    • Home: Northern Ireland Current: British Antarctic Territory
                    #24
                    Any pictures of the piece in question?? Sounds like access is gonna be limited...
                    whats holding it to the block? just clips?
                    Brian
                      Defo interested if you're making a batch Rob, seems like this is another turbo hose pipe time bomb...
                      • GT500
                        • Jun 2006
                        • 2181
                        Access is easy.
                        The one on the back of the block has 6mm headed hex head bolt holding it in.
                        No 33
                        Doc1.doc
                        And no 12 for the heater one.
                        Doc2.doc
                        Rob..
                        87 UR 20v ABY
                        97 S6 Avant
                          Ta muchly
                          • GT500
                            • Jun 2006
                            • 2181
                            I spent most of saturday on these,
                            [IMG][/IMG]
                            Rob..
                            87 UR 20v ABY
                            97 S6 Avant
                              Any plans for a production batch or are these a one-off?
                              • Acidburn
                                • 13459
                                and nice work rob, looks like a good solution to a potential problem with the age of some of these cars.
