Removal of engine wring loom (incar side)
  • K7ERG
    • 1711
    I am looking at taking the loom from the car i am breaking.
    Do i have to remove the dash to get better access?
    Is there a place it joins to the car loom?
    Any help would be great.
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
  • gedu
    • Feb 2007
    • 295
    Remove whole interior for better access. Harness connects a few sensor through connectors, but quite a bulk runs straight from ecu to powerstation and engine compartment. And of course, harness comes to engine comparment from at least 2 different places.
    So in short, dismantle everything you can before starting to remove wiring.
    All quattro products have been dermatologically tested, and are safe for daily use.
    • Nace20
      • Jul 2007
      • 721
      • Country: Slovenia
      In urS4/s6 it goes only thru one hole to motor, at pasenger under servo.
      It is esaier if you take out dash, than you just have to take yelow cable from instruments and folow them to ecu, and then go out and pul it to the motor, it is esaier, than into the cabin.
      S2 limo
      • spink
        • 4382
        I took one out of an S4 last year,what a ball ache.Never again
        • quattrostyle
          • Oct 2006
          • 6229
          same here, won't do it again
          • terrybullwon
            • Mar 2006
            • 8782
            Bah its a easy job.
            You will need the dash out though
            Chef
            • Crawford_S2
              • 1555
              Yeah defo dash out, and heater box, and fan assembly. Lots of the loom is behind all this on the firewall.
              Ragusa Coupe gone!
              • spink
                • 4382
                Taking one out of an S2 is childs play compared to the S4
