Front Pulleys / Torsional Vibration Dampers
  • driftin jo
    • Sep 2007
    • 2222
    Originally posted by Matt_D
    Thank f&&k for a moment there i thought i ordered the wrong one!
    Oh and this is what £398+VAT of Audis finest looks like (i did'nt pay that)
    So if the front pulleys are a 2 part system then i take it the bottom pulleys themselves need to be balanced too otherwise the vibration damper might as well not be fitted ?
    I,m sure that all the parts Audi make are balanced to a good standard to start with,but if you read all the information in this thread ie the links at in the first post you will understand that the damper HAS NOTHING TO DO WITH BALANCING, so suggesting that if it is not balanced you might as well not be fit it is just daft.
    Wile getting any of the parts in you engine balanced better than they are now is hallways a good thing for you engine, even if the hole bottom end was not assembly was very well balanced it would make no difference to the function of the damper, it is a torsional vibration damper.
    • HPmuirt
      S2Forum April Fool
      • Apr 2005
      • 3014
      I may have got this wrong as I am not a mechanical engineer, but from my reading of the above posts and the links articles, the reason for fitting this damper has nothing to do with smoothing vibrations caused by an imbalance of the rotating parts (crank, FW etc) but only to relieve torsional (i.e. twisting) forces and vibrations generated in the crank itself.
      Calling it a vibration damper is really the problem here as everyone always assumes that the vibration is caused by a balancing issue so let's just call it a 'torsional damper' to keep reminding ourselves of its actual purpose.
      It therefore sounds to me that you can bolt up what you like in terms of flywheels and clutches etc and get it all balanced, just remember to bolt on your torsional damper as well
      Cheers n
      Si
      Subtle mods here and there
      2011 A5 3.0 TDi - Lava Grey
      • driftin jo
        • Sep 2007
        • 2222
        Si,
        You understand it perfectly and have it spot on .
          £398+VAT
          Do we know the differences between ABY and 3B pulleys? I know that the 3B item is lighter, just wondering what was different? I would make the logical assumption that it is best to keep the pulley with the correct crank based on the information above.
          Do we also have details on the 2 parts of the front pulley as there might be an option for weight reduction in the pulleys whilst retaining the the torsional damper...
          Final question, does anyone knnow if there is a max RPM on the TD?
          • Flat on my back
            • Jan 2007
            • 2449
            Main diffs are ABY is ribbed aux belts, 3B/7A is 'V' aux belts.
            HTH.
            Carlos.
            • mcandmar
              • Apr 2004
              • 5118
              3B vs ABY pics here http://www.s2forum.com/forum/showthr...ight=3b+pulley, only difference is the alt drive belt and less weight.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
                ABY one is a monster isn't it!!!
                • Ross
                  • Aug 2005
                  • 3399
                  My thoughts on this... read a little into Pulley's myself, and have read the links posted at the start of the thread. I'd go down the route of lightening the stock pulley if I wanted to lose some rotational weight, I'm sure there's a pic of someone who took about 1kg off it on the forum somewhere? And change out the alternator pulley.
                  That said, from the experiences of others with the I5 it would appear that the crank is strong enough to take any torsional stress given to it at stock power levels. I'd imagine if it's going to break, it would do so very quickly.
                  Each to their own I guess, these items look damn impressive and I'd be tempted to change the alternator but I'm sticking with my dampener! Excessive torsional oscillations in my shaft sounds painful anyone seen that vid of the bridge that shakes itself to pieces when it starts oscillating at its natural frequency??
                    #24
                    Tacoma Narrows......
                      Tacoma Narrows, one of the first things you get in any vibration based education module
                        The first Tacoma Narrows Bridge opened to traffic on July 1, 1940. It collapsed four months later on November 7, 1940, at 11:00 AM (Pacific time) due to a physical phenomenon known as aeroelastic flutter caused by a 67 kilometres per hour (42 mph) wind. The bridge collapse had lasting effects on science and engineering. In many undergraduate physics texts the event is presented as an example of elementary forced resonance with the wind providing an external periodic frequency that matched the natural structural frequency (even though the real cause of the bridge's failure was aeroelastic flutter[1]). Its failure also boosted research in the field of bridge aerodynamics/aeroelastics which have themselves influenced the designs of all the world's great long-span bridges built since 1940
                        Does the S2 suffer aeroelastic flutter?
                          They do, ask Doug about his experiences on a French Autoroute
                            haha haven't spoken to Doug in ages!!!
                            • saltinot
                              • May 2004
                              • 1946
                              #29
                              The "shade tree" mechanics here in Georgia refer to them as the 'harmonic balancer' which I always thought was goofy, but it actually better defines them.
                              • driftin jo
                                • Sep 2007
                                • 2222
                                No it doesn't as they don't actually balance anything ! They absorb torsional vibrations of the cranks resonant frequencies. Hence the proper name “Torsional vibration damper”
