Valve guides - Help needed please!!
  • merlin's S4
    • Jan 2005
    • 1539
    I've got a 7A head in the machine shop at the moment which is being rebuilt with new valve guides. The head is eventually going on my AAN and has already had the required mods carried out to fit (hall sensor bracket, water manifold machining etc).
    The problem, (if indeed it is actually a problem) is that the new valve guides that I have are different from the original ones in the 7A head. Both guides are the same size in both diameter and overall height but if you look at the picture below you'll see that the new guide (on the left) has a collar which I believe should sit against the surface of the head once it's pushed in. The thing is that doing this will make the guide sit approximately 3mm further down into the cylinder than the original guides which have been removed. I've marked with an arrow on the picture the point where the original guide was seated in the head. For reference the old guides stick out approximately 11mm from the top of the head (cam end) where as the new ones would be 8mm if fitted down to the collar.
    Are these guides the correct ones? Should they be fitted so that the collar touches the head? And is that 3mm going to cause any problems? Any help would be much appreciated!!
  • Rusty
    • 18953
    Looks a bit strange... sorry I can't make a more intelligent observation
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      Are the new ones made by Febi? Is there a part number on them? They have the collar on them but fit ok. You also have to grind the centre hole in the washers that go under the spring seats, so they fit over the collar on the new guides.
      SS
      • volcano rs
        • Jun 2005
        • 2265
        thats right make sure the shims are machined to accomodate the guide other than that they are ok to use .
        • merlin's S4
          • Jan 2005
          • 1539
          Thanks Stu! On the box it says HANS PRIES topran part # 100 247 965 It also quotes the correct Audi part # for replacement, 027 103 419
          So as long as the washers are modified I'm good to go??
          • 20Vcqdriver
            • 829
            I used the Febi versions without a problem. Fitted to the same depth as originals.
            1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
            2004 A4 2.5TDi convertible, re-mapped to 180bhp
            2011 A5 sportback 3TDi-Backbox delete, remap
            • merlin's S4
              • Jan 2005
              • 1539
              Are the Febi versions the same or is the collar lower than the ones I have?
              • merlin's S4
                • Jan 2005
                • 1539
                Just looked up some different brands of guide on the net and in the pictures they all look the same as the new ones I have so I think I'm ok.
                Thanks again!!
