No 5Volts on MAF :(
  • nemilosu
    • Nov 2008
    • 196
    • Country: Romania
    No 5Volts on MAF :(
    AAN engine.
    why ?????????
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    ECU is quite rigid in terms of power supplying for the MAF. So check cabling. Its far more often cause for trouble, than ECU itself.
    Sau
    • nemilosu
      • Nov 2008
      • 196
      • Country: Romania
      Sau
      i have 5V on throttle.
      how can i check the 5V on maf ?
      when i have to have 5V on maf ?
      on idle speed?
      on high rpm ?
      with ingnition on and the engine stopped ?
      • Pirvu Eugen
        • Apr 2007
        • 1978
        • Country: Romania
        there is no 5 volt....
        S2central has a verry good description about...
        Hope this helps!
        • nemilosu
          • Nov 2008
          • 196
          • Country: Romania
          Hope this helps!
          • JP
            • 1858
            I plummed my datalogger into the wiring loom near ECU plug to read 5v MAF signal at idle it will read approx 2.39v
            The signal wire runs to pin number 7 on the ECU plug (can't remember the colour though). Put positive lead of multimeter to this wire and earth the other one to chassis.
            hth
            UrS6 Stroker + HTA3586 =
