Hey guys!
We are having a problem here with a car that uses SQ maf. Car has SQ maf with resistors, changed cooler, manifolds, turbo, 444cc injectors etc. The problem is that when I release the throttle, motor stops working. It doesn't happen every time this way, but it happens quite often. The thing is that we took for on approval Hamon-Motors software that supports orange injectors, SQ maf, 300kpa MAP, it looks like something is wrong. One fellow who owns a car with MTM 420ps setup, told us that when he disconnects ECU, car doesn't work properly for a long time and then in some point it starts working again. What I want to know is that does SQ maf has some kind of gonzos (individualized qualities) so that ECU needs to learn setup a bit longer? I know that with usual maf motronic learns setup for about 100km or so.. But is there anything different with SQ maf?
Thanks,
Marko
Thanks,
Marko
,try with the RS2/aby MAF THAT BOTH ARE THE SAME, or with the 3b/aan that both are different
