Cunning plan to plot the MAF curve
    I have come up with a cunning plan to plot the output curve of the S2 / RS2 MAF...
    Why - cos it is completely undocumented in the public domain. I have politely asked a number or Bosch agents for datasheets but even they don't have them to divulge. Quite why Bosch is so protective about 20yr old technology I dunno.
    ANyway - here is the plan... Fortunately there is a range of Bosch hot FILM based MAFs which do have documented data in terms of an output voltage for given mass of air intake (grams per second for example).
    The plan is to buy such a hotfilm MAF and bolt it up in front of the (R)S2 MAF and hook up both MAF outputs into an ADC. Then simply take the car for a wee drive and I'll be able to plot the RS2 MAF characteristic by correlation against the hot film reference MAF.
    This is the only viable way forward as I haven't been able to locate anyone with a flowbench capable of such throughput - then I figured I can use my car as a flowbench !
    So onto the question of ADCs then - anybody got any experience of something like this -
    Its a UK firm who make an award warning PC based oscilloscope for lots of money - they look clued in and their ADC seems to have the right capability for my needs. 20kHz is plenty fast enough sample rate and it offers lots more channels for growth into other test scenarios.
    Once I have this data we will then have some means of being able to pinpoint MAFs which are in/out of spec. I'm using a fresh RS2 MAF here, but will happily test as many MAFs I can get hold of for more diligence.
    I'll have to cough up for one of these Bosch hotfilm jobbies - there is at least one with 80mm form factor - all I need is some ugly tubing to link them both together - and get the airbox out of the way. ECU will run of normal MAF for driving of course.
    The eventual upside of this is being able to unlock the MAF scaling secrets in the ECU so that we use bigger / better MAFs than the stock item. That has three main benefits :
    1. Better dynamic range as the factory one maxes out quite early. Its over 2V at idle already - duhhh
    2. Less restrictive intakes on big upgraded engine with a means of putting RS2 MAF internals into a bigger tube for example.
    3. More reliability with the possibility of migrating from precarious hotwire to more robust hotfilm technology... negating the need for hotside MAF locations and/or going to aftermarket ECU
    I think the MAF scaling stuff will hurt my head for a long time - that is the eventual goal, but for a little spend there should be some easy wins in the short term.
    Any other suggestion on good ADC with USB connection under £200 ?
    Ta,
    Paul
    Hasn't URS4 boy looked into MAFs before? Might be worth speaking to him before you start as he might have some useful data.
    • twoqu
      • Sep 2003
      • 3103
      Going back some years the technical side of AMd, think it was called Millford something, used to a hot film afm upgrade for Porsche and I think some Golfs. It was a substantial improvement on the Porsche I seem to remember.
        Great project Paul, isn't Monstereddie running a hotfilm MAF on motronics?
        • AndyP
          • 6049
          That was back in the good old days when Geoff Everett ran AMD, he's still involved with Milford though.
            I've certainly heard of the hotfilm MAF being added to porkers - there's a few diy tuner web sites talking to that - more often associated with removing the airflap style of metering on Bosch L-Jetronic systems... The hotwire LH systems followed that, then got reused in like of our Motronic.
            I'm hoping to help someone else in such a Porsche application to migrate it from flappy pot of 1989 vintage to HFW or HFM. The tricks learnt from that should hopefully be generic enough to help fathom the mysteries of this on S2/RS2 ECUs
            • Flat on my back
              • Jan 2007
              • 2449
              Just been on the s2central site.
              Cant find a 'make a donation' link...cant think of any other way of helping out with all the sterling work your up to.
              Sterling work...
              Carlos.
                Sterling work...
                It's on the front page
                • BrianSmith_S2
                  • Jun 2005
                  • 1342
                  • Home: Northern Ireland Current: British Antarctic Territory
                  Ive got some experience of using Pico technologys ADC-11 (see photo). I use it at work for analysing and fault finding on some of the electronic/pneumatic servo control systems were developing at work. I use it to read voltages direct and to monitor air pressure via pressure to voltage convertors (see photo)
                  The picolog software is nice n easy to use, once youve played around with it. The old version i use requires a serial connection, but the new one is USB. Im sure it would be ideal to read outputs from the maf, and to also (with the air to volt convertor) measure boost pressures, etc.
                  Think they retail for less than £100 with the software.
                  Brian
                  • mcandmar
                    • Apr 2004
                    • 5118
                    Our 993 uses something similar, just looks like a bit of circuit board stuck in the air flow. The body of the maf looked very similar to an S2 item which caught my interest, having seen people mention problems with hot wires breaking in high HP applications it seems a plausible solution, its even made by Bosch.
                    91CQ20v - Gone to a new home
                    93UR-S4 - The Magic Carpet
                    94S2Bus - The Emerald Express
                      Just noticed the picotech is limited to max voltage input of 2.5V but that's easy enough to overcome with a voltage divider.
                      Picotech is about right money and functionality I think... Hah - I aint priced the hotfilm MAF yet - hope thats not a nasty surprise !
                        Bosch HFM5 - looks like five family members... And the big one is fitted to SCANIA and MANN trucks. Thats some MAF with a 130mm diameter
                        1000kg/hr capability - thats 278g/s...
                        Bosch 0 281 002 421 and looks like sub £200 brand new. There are a few other choices which appear to have usefully extended dynamic range vs the S2/RS2 item.
                        Datasheet is online if you look hard enough - but its also published by Bosch in another publication.
