Im new here so treat me gently..LOL..I used to build LOT or Rally engines when i was in my early 20's.None were turbo charged but i used to use very high CR's and dependant on engine size etc very high revs.
I found a cheap way to rods that were VERY strong.I used ones out of diesel engines.They take a lot of lightening the need to be dynamically balanced but they have plenty of meat at either end to playwith and i used to mix and match bearings etc no problem.
All you guys need to do is find a rod thats the same length, or very close and let the engine shop do the rest.
I’ll do a fine tuning to the ECU and rise the boost to something like 1,55bar. It will be flat, from the point it makes this boost until redline.
