i have an rs2 intercooler and cross member on my 3b coupe, the car came with it fitted but its not quite right, after replacing both engine mounts i went to refit the front crossmember and snubb mount and it was an inch out ! it was in a "forced " position prior to removal, i remember noticing it when i done a cam belt, i "presumed" the early 3b cast mount and steel cup are not compatable to an rs2 cross member, i would of thought the captive nuts are an inch higher on an early car, i have rectified the problem by making a custom front mount, ill move the captive nuts in the crossmember when i have more time then put a standard front cup mount on.
basically wondered if anyone had come across this before, there is nothing wrong with the car , everything lines up ok and an inch is quite a lot!
