-URGENT- small cracks in the head
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    hello misters
    sorry for the pictures quality but does someone know if these small cracks between the spark and the valve seat it´s too dangerous???
    i´ve discovered it whem i opened the head these last days...
    after machining the head the specialist said me that it will be some dangerous for work with this head + RS2 turbo potential...
    what can i do??
    -forget this head and buy a 7A head in good condition???
    help¡¡
    -Tomas-
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    those seem to go all the way to the seat valve.Either find someone that can service that head or get a head without cracks.
    i ended up with 3 cyl.heads before i found this one i use now that doesnt have any cracks.However one aan that i have i will have it fixed at some point.
    • SteveH
      • 4460
      There is an acceptable level for cracks in the head. The 3B erWin manual has the definition of what's ok. I think it mentions the depth of the cracks and how many plug threads they run through. Lemmi see if I can find it, if not, I'm sure others will advise you. If your going for more than standard power it may be wise to look for a decent 7A head and have it machined. I think Spink on the forum has done a few of these.
      91 Modded 3B
      14 A6 Avant Black Edition
      • valjo
        • 1110
        • Country: Latvia
        as long cracks arent between valves dont worry. i saw many s2/s4 cracked heads but cars run great .....
        Audi Coupe S2 1993
        Audi V8 4.2 1993
        Audi cabrio 1998
        • aelred
          • Jan 2005
          • 761
          If you are going to pump big BHP forget it, go for a good head to start with, will be cheaper on the long run. Small cracks might be alright on a standard engine but not on uprated one.
          Aelred
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            thank you friends for all replies
            today Peter kowaksch after saw my e mail + head pictures said me that i will can drive in theory perfectly for 20000kms or more ( i think that these 20000kms are going hard with the turbo ) BUT in the next future/chance try to buy an other head
            (7A,3B,ABY,AAN,ADU...) because weld the head it´s not a good option here
            my actuals cracks between spark/ valve seat are not to huge...Peter´s said
            i am more happy now just after bought my custom metal head gasket for compression drop.. 8´8:1... the hight compression levels kills the head
            ,for the next future.... a stroker project i´ve bought a AAN ebgine block with 220000kms in very good condition for 300€¡¡
            SEE YOU
