I've got an intermittent issue with the crank sensor (grey plug). It's the wiring or the plug. Can you buy the plugs separately? How do you pull them apart to inspect the wiring? If it's not the plug then I'll have to cut the wiring back and splice in some wire that's not knackered Got to sort it as it's annoying me.
AES are the leading suppliers of auto electrical components and accessories for modern and classic vehicles. Marine and boat electrical parts also supplied. If you are wiring or rewiring a vehicle, shop online or download a free AES catalogue and buy via mail order. We also have a French Website...
Took the connector apart and had a good look, nothing look untoward. Put it all back together and it seems to work fine. Very strange... have to keep an eye on it and see whether I get the intermittent starting problems again. It's defo that plug as VAGCom identified it originally and a little wiggle sorted it
I've just heard back that all parts are available from Audi if required
