Little Intercooler of Horrors!
  • Paulgo
    • Jan 2005
    • 498
    I finally got round to changing my 3B intercooler to the modest upgrade of an ABY unit. Other than benefiting from a slightly larger intercooler it was also noticed at a garage meet a few months before I bought the car (then known as “Jimmy”!) that there looked to have been some repair work done at some point in the car’s history to the intercooler. I didn’t realise just how much!!
    Firstly the front! :
    It looks like its hit something like a sign post that’s caused damage to the top of the intercooler and bent the x-member. Rather than replace the intercooler they simply bodged it up! Looks like they might’ve had a go at the O ring joint too! Not sure if I’ll ever get them to split!
    You can see from this angle how its caught the x-member!
    But the back is even worse!! Probably from being pushed back into the pulley wheels:
    Oddly the x-member has been sprayed from dark blue – and not very well – so doesnt seem to be the original unit! The cables running across the top has been taped over i think when it was sprayed and I hadn’t appreciated this until it was off the car.
    To be fair I don’t think there was an issue with any loss of pressure with the old set up. They may be ugly but at least the patches were effective! However, I feel much better having nice ABY replacements on. The mounting bracket for the slightly larger ABY intercooler is quite different from the hanger set up the 3b uses. I was lucky to source a pearl x-member and I stuck a 60/80 silicone reduction pipe at the O ring end for good measure.
    For any other 3B owners looking to do the same job other than the intercooler and x-member you will also need a couple of ABY boost hoses: turbo to intercooler and x-member to intake pipe. Whilst the O ring joint is the same both outlet pipes are orientated slightly differently on the ABY. The feed to the turbo on the intercooler bends in towards the engine and I don’t think the 3B pipe would twist sufficiently. The ABY x-member pipe comes straight out whilst the 3B bends upwards .
    Old against new
    Its therefore also possible to replace the complicated accordion ringed and ribbed pipe to metal elbow to connecting hose assembly with the straight through and far less fussy ABY pipe. It joins the intake pipe at roughly the same place so it possible to get away without using the plastic ABY replacement if you don’t have one. Not sure if there’s any true different in length, but it works!
    Paul
    Trick Pearl White 1992 3B S2 Coupe. Porsche 996 monoblock stopping power! HID Seeing power! Mmmmm Miltek!!!
    Trick Indigo Pearl B5 S4 Recaros, Bose , Mmmm Miltek!!!
  • Acidburn
    • 13459
    Glad you got it sorted tho, looks like you mention its been hit quite substantially and pushed back. Have you noticed any difference since changing?
    btw nice picture
    • Jas11n
      • 5067
      Not all the ABY's solid pipes (running next to rocker cover) were plastic Paul. Earlier ones were metal too, like the 3B's.
      I'll pop up with my spare plastic one next weekend
      Feeling better today, but then of course that's cos it's not the weekend, it's Monday and I'm at work
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • Paulgo
        • Jan 2005
        • 498
        Well i didnt realise that - thought all ABY's were plastic Glad to hear you're on the mend matey and we can sort the pipe next weekend
        Paul
          My god the curse of Jimmy will it ever stop? More come backs than the Police Academy series!
            Paulgo,
            Informative write up and good photos - thanks.
            As mentioned, is there any noticeable difference in how the car goes, apart from the fact that it no doubt feels psychologically much better?
            Kind regards.
            • Paulgo
              • Jan 2005
              • 498
              Cheers guys
              The worst has to be the wiring from an amp install that was earthed to the seat post for the back seat!! But I think I have most of the "Jimmy" out now!
              Ive not really been able to give the S2 a good enough run yet to assess any performace gains - tho I would expect they would be modest and subtle given that is not a big difference in the IC's - but I have still got the plastic pipe from Jas to fit Cant say Ive noticed anything much so far. To be honest Im just so glad to be rid of the old unit that was patched up better than the frankenstein monster!
              cheers Paul
                Paul,
                Agreed, thanks for reply nonetheless.
                Kind regards.
                • s2_bo
                  • Oct 2005
                  • 6067
                  Amen, "Jimmy the return"
                  Or did we have that one already, this must be - "Return of the Jimmy - Part 2"
                  91 S2 coupé - RIP
                  98 S8 - Luxury barge
                  • Jas11n
                    • 5067
                    "Jimmy" is long dead
